assistance with lap time correction
eightysixtuned
Post by eightysixtuned »
hello,
i did read a thread that for assistance with lap time correction i'll need to contact someone? is this still the process? i did read that lap times can be off due to dropping of GPS satellite signals. I did attempt to have this auto corrected, but when this occurs, it splits the 1 single lap which consists of 2 laps into 2 laps with the incorrect start and end locations for each.
Re: assistance with lap time correction
Please export the multi lap to HLPTRL and send it to Harry@gps-laptimer.de
Make sure you export only this single multi-lap and not a larger range.
Add a note “please check if this can be split / repaired”.
eightysixtuned
will do. thank you harry!
