Lap Timer and Armband (Go-Karts)
Falko83
Post by Falko83 »
I'm searching for a good lap timer to use with Go-Karts. The thing is I'll be using it with the iPhone in an armband.
Will the laptimer work properly attached to my arm?
Thanks.
Re: Lap Timer and Armband (Go-Karts)
Yes, it will work, but you will not get reasonable acceleration values. You can calculate them from the GPS plot later, but that's a different story.
crofrog
Post by crofrog »
Will the lap to lap comparison and segment timing be reliable?
Chris
Yes, think so. The acceleration topic is not related to lap timing / comparison.
solive31
Post by solive31 »
Harry, is there a tutorial or website explaining how to calculate acceleration from GPS plot?
TIA
Sandro
What's the background of the question? You will rarely use it as the standard is to measure it. Only in case calibration didn't work, you want to calculate it from GPS. This means LT derives the corner radius from the gps plot plus speed and calculates lateral acceleration from it.
solive31
Post by solive31 »
As Falko83, I'm racing with Go-karts and an armband. As you said, I didn't get reasonable acceleration values, that is the reason of my question.
tks
Sandro
The function to calculate acceleration from GPS is located in Lap Details. It is optimized for 1 Hz GPS recordings.
solive31
Post by solive31 »
I found it!!
Many tks!!
Sandro
