OBDLink LX and missing data
Shrekmachine
Post by Shrekmachine »
some of my data is not populated. E.g Oil Temp, Power and Torque. Is there a specific OBD Tweak I need to use for the OBDLink?
Android 5.1.1 Porsche Panamera
Cheers
Frederic
Cheers Shrekmachine
Blackberry Priv and Porsche 970
Re: OBDLink LX and missing data
Porsches do not map oil temperature to the OBD standard PIDs - they prefer to keep it secret... To get power and torque, please set the engine values in your vehicle's details dialog.
Shrekmachine
Hi, all data in the vehicle are maintained. I can share my .hvel data if you want.
Cheers Shrekmachine
Wait until you are on the beta and submit your vehicle for certification - it is a new feature in v20.
Besides data entered, v19 requires the MAF PID to calculate power and torque. You may check if it available in Sensor List - OBDLInk LX - Info (while connected). V20 will use MAP in case MAF is not available.
Shrekmachine
great, will check later today the MAF
Cheers Shrekmachine
Shrekmachine
Hi, I checked with OBDLinkt and HLT. Oil Temp is displayed with OBDLink. MAF is not. Just to be sure I made screenshots with all transmitted data. I'll send a link to Dropbox with all images.
Cheers Shrekmachine
Shrekmachine
PS: cooling liquid temp is 15 degree higher then in BC.
Cheers Shrekmachine
Thanks for the data.
EOT (oil) is PID 015C and not delivered for your car.
MAP is PID 010B and available (but not used in v19).
MAF is PID 0110 and not available (but will be calculated from MAP by v20).
The OBDLink app either has some Porsche manufacturer information backed in (custom PIDs) or generates an estimate for EOT from ECT. I will re-check that once I add custom PID support.
A hint for your settings: try LapTimer ‣ Administration ‣ Settings ‣ Expert Settings ‣ OBD Tweaks ‣ CAN Multi Requests ‣ 3 / adaptive. This will double you update rate ;-)
Shrekmachine
or is it cooling water?... Anyway, waiting for the alpha, let's take it from there.Let me know in case you need more data then.
Expert setting changed. merci
Cheers Shrekmachine
As written above - they may use a custom PID. These custom PIDs are make / model / year specific and not supported by LapTimer so far. ECT (= engine coolant temperature) is available for your car. Please search for custom PIDs here on the forum and elsewhere. It is a cumbersome topic.
