Using HLT Alone
JESFromRIC
Using HLT Alone
Post by JESFromRIC »
Simple and straightforward question here:
Can I use HLT on my Samsung Note 3 as a 100% stand-alone device to display my current speed and record my lap times?
No GPS puck, no additional data recorder, no special wiring or complex computer interface?
I run at VIR, I am headed to Road Atlanta and Atlanta Motorsports this spring and do SCCA hillclimb events.
That is it.
I don't need or want OBD feedback, complex data, lap overlays, synced video, etc. etc. etc...
If the answer is, "No" then please explain.
Thank you,
John
Re: Using HLT Alone
Yes, the Note3 should be fine for stand alone operation. Internal GPSes deliver 1 position a second only. This is the reason data analytics are limited without an external GPS (coming at 5, 10, or more Hz). As long as you mount the Note 3 in a position you get a good GPS reception (center of windscreen), timing accuracy will be fine as LapTimer interpolates the 1 Hz position stream to derive timing at 0.1 to 0.05s accuracy. As this is your focus - fine.
The only equipment you actually need for the Note 3 is a mount and an in car power supply. It works without power supply too, but chances are good your batteries are drained when it is getting most interesting.
JESFromRIC
Re: Using HLT Alone
A ProClip mount with built in hard-wiring is already on my workbench.
