Internal GPS used even if external is recognized?
mk1 black limited
Post by mk1 black limited »
Hi! Just noticed, while preparing a video for overlay, that GPS Sensor under DATA RECORDING says 'Internal @ 1.0 Hz' even though I checked before I went on the track that the external GPS sensor was indeed recognized and was in use?
Re: Internal GPS used even if external is recognized?
Probably not... Which smartphone and GPS do you use?
mk1 black limited
iPad Mini and XGPS 160.
O.k., for this combination, the update rate and source analysis generating "Internal, 1Hz" is definitively correct. The internal GPS has been used. This can be due to some disconnect while driving, battery etc. Not common but can happen. LapTimer is falling back to internal sensors silently in case the external solution is not available any more... You will get a pop up shortly - but this is easy to miss while driving.
I'd suggest to retry during a dry run. Use e.g. manual start / stop in Classic View during a drive to work and check the recording afterwards.
mk1 black limited
Will do :)
