Split Laps
llan981
Split Laps
Post by llan981 »
I read somewhat that after 18.1 you can split laps. How do you do a basic split when you may have 2 laps combined.
Re: Split Laps
The first question is: Is the data in the Lap List? If not, I doubt that there's anything that can be done.
llan981
Re: Split Laps
Post by llan981 »
Data recording shows 2 laps and 3383 GPS fixes.
Re: Split Laps
[Thread moved to "Using LapTimer"]
To split a recording that should actually be 2 laps into 2 recordings 1 lap each, go through these steps:
1) Make sure you have the proper Track Set loaded
2) Navigate to Lap List -> the multi lap recording -> scroll down to Recalculate -> select "Validate Lap"
llan981
Re: Split Laps
Post by llan981 »
On data recording preview it clearly shows two laps. It did not work on validate lap wide.
Re: Split Laps
What exactly happens for validate laps? Please name the track set used and post an .hlptrl export of the recording it is applied to here.
