BMW vrs GoPoint BT1
Re: BMW vrs GoPoint BT1
Thanks for sharing your experience. Seems to be a pretty low level issue initially. To my knowledge 177.0.5 is the last version (need to check when connected in my car) but GoPoint will clarify on this for sure. Please keep me posted, although this is a new flavor, it is a BMW M3 again...
fanredwings73
Looking at the GoPoint support site, 177.0.5 is the latest firmware as of March 28, 2013.Harry wrote:Thanks for sharing your experience. Seems to be a pretty low level issue initially. To my knowledge 177.0.5 is the last version (need to check when connected in my car) but GoPoint will clarify on this for sure. Please keep me posted, although this is a new flavor, it is a BMW M3 again...
https://gopointtech.zendesk.com/entries ... t-Releases
mousemaster
I have a few screen shots to show you. I eventually got the BT1 to pair to my Iphone 4. It works with my Mercedes S430 as it should.
It still won't work with my 2004 BMW M3 with a stock S54 engine. Here are the screen shots. If you have any final recommendations or ideas I would welcome them. I did send off several inquiries to the Hamilton folks for troubleshooting. However, they won't even answer me now.
- Expert Settings.png (97.45 KiB) Viewed 6726 times
Please give us some more days, I work with several other BMW drivers to find a solution for this. It is pretty difficult as I do not have a BMW car around for testing. So it is always a long ping pong to generate logs / adjust the code and test again.
mousemaster
This just came into my email box this morning from them:
Connectivity to the BMW M3 has been frustrating for some time. Our thanks to Ray, with his help we have found a fixed an elusive timing issue with the ISO 9141 communication. The latest release of firmware for the BT1, BT1A and GL1 has these changes incorporated. The BT1 App will re-flash your hardware with the new firmware just released.
Best regards,
Tod Hamilton
GoPoint Technology Support Team
Best regards,
Tod Hamilton
Yes, please check if this is related to your issue. As I have several (different) issues with BMW OBD replies this will fix some, but probably not all issues. Looking forward to your report!
mousemaster
I think the problem is now solved. Many thanks to you Harry and the BT1 team. Success for the S54.
- BT1 image.PNG (96.96 KiB) Viewed 6705 times
mousemaster
Next issue:
I tried out a sample video recording. I took a snap shot of the playback to show the problem. When I choose overlay, the phone seems to try to do a video overlay. However, during playback, the actual data is not presented. You can see there is a throttle sensor and other parameters, just no data.
Help !
Help !
- no data II.PNG (55.37 KiB) Viewed 6701 times
Please check your recordings (especially GPS). There are no known issues with the overlay, but missing data due to missing quality data from GPS and OBD is a frequent issue. So please enter the Lap's Details and verify the data: follow the preview row and flip through the charts to understand what data is available and which is not. In case you cannot find the issue yourself, please consider either opening a new thread or switch to email. We need to stay on topic here
mousemaster
Right, stay on topic.
What is the appropriate email address?
Thank you.
Thank you.
