Overlay video with NULL Mulitcam Link
Re: Overlay video with NULL Mulitcam Link
Hi Scott,
This actually looks fine, I get this list of laps:
iOS Simulator Screen shot 26.06.2013 18.16.56.png (266.25 KiB) Viewed 2335 times
The lap data itself is o.k., just the video links are corrupted as discussed. Please remove them like posted above and add the video manually again.
The correct way to relink is to add the GoPro session video from scratch: in any lap included in your big session video not showing "nan", enter Lap Details. Press "Edit" and a) remove the void links b) add the GoPro video ("Add Video"). LapTimer will ask you to select the lap's end within the video - which is exactly the step I wanted to make more convenient by introducing the GoPro MultiCam support. In your case, you need to go through the process.
escottc
Post by escottc »
Your Zen patience is astounding....however.
Unfortunately all laps are "nan" under LapTimer Integration so I'm unable to access to edit. I get this message when selecting a lap:
"Information: Changing the sync point is possible for local video files only. Please download the video to your device to change lap/video synchronization."
The video is in my Photo Library (I've done this before with autocross events with success), but I think that HTL can't see it because of the null value associated. From my understanding thus far if I could manually ad a link value to the Video Details it could work, but there appears to be no way to edit that.
For each lap: Lap Details ‣ Edit ‣ press red delete button ‣ press Delete ‣ press red delete button ‣ press Delete
The double Delete is necessary due to the (null) situation.
escottc
Post by escottc »
Thanks Harry. I was able to delete then relink the video, but everything seems really off. Anyhow, the first lap that is listed is #4 so that ads to the confusion in syncing. Speed is 0 then in the teens. My GoPoint didn't seem to connect as I thought it had either. I've noticed a few times the GoPoint won't turn on or disconnects/off for now apparent reason. Seems a loose connection I think. I'll try some testing by driving in a circle some place, creating a track of sorts, to see if I can get it to work properly. Thanks for all your help. There are lots of connections to manage so hopefully it was just glitching.
