XGPS150 5 Hz update.
tulloch
Re: XGPS150 5 Hz update.
Post by tulloch »
How do you check what version of the firmware the Dual is using?
Thanks.
Start the Dual Status Tool (available on AppStore). The firmware version is displayed in the bottom of the "XGPS150 Status" tab.
tulloch
Post by tulloch »
Ah, there's an app for that. :) Thanks.
bulls23
Post by bulls23 »
Btw...the app sucks too...firmware updates over the app would be nice (ok, I don't know if that would be possible over Bluetooth) or at least some kind of Push service for new firmware releases etc.
bulls23
Post by bulls23 »
Harry wrote:Start the Dual Status Tool (available on AppStore). The firmware version is displayed in the bottom of the "XGPS150 Status" tab.
Did you forget HLT shows that too? :lol:
In "Sensors" simply klick on the little blue arrow / circle of the connected XGPS and you will see the firmware version too.
Yes, but only in case you are lucky and run 17 already ;-)
bulls23
Post by bulls23 »
Aaahhh, I see :oops: Didn't notice it was a new feature
Just to close the recent discussion on firmware availability: I got information from Dual the web site transition is completed now and the firmware registration should be available again: http://gps.dualav.com/firmware/xgps150
Cadaver
Post by Cadaver »
I also only ever get 3.9hz with the Dual XGPS, as reported in lap timer. Is there anything to do about this? I'm running the most recent firmware, and I have tried this on a couple of devices to ensure it isn't a setting problem on my device. I get 3.9Hz on all.
Any ideas?
Please test your update rates again once v17 is available. I just tested the Dual and receive solid 5 Hz (even when increasing precision to one decimal digit.
