Problems with video overlays
Re: Problems with video overlays
Chall392 wrote:I deleted sessions where the RPM and TP were zero so there is no way for mr to see if that data was whole. During the sessions subsequant to the above, I didn't capture video but the files show that RPM and TP were recorded.. Any idea why the overlay didn't work fullly?
Connection problems with the OBD?
Chall392
Post by Chall392 »
Thats what I thought could be a possibility but I didn't change anything from the two sessions in which the overlay was incomplete vs the sessions where just data was recorded. I also ran LT on the way to the track and it was showing RPM and TP
Before going to the track, and on the way to the track I tested and everything was good. It just seems that while my phone was capturing video AT THE TRACK, LT was not reading RPM and TP. I wish I hadn't deleted the two sessions....would like to see if the files contained RPM and TP data.
Have you seen this before? Any other ideas please.
Please keep in mind this is a long integration chain from car sensors, to car bus, across the OBD plug, through the dongle, via wifi, LT connection, LT processing. There are several areas that can break or will not work from time to time. What I recommend is to take some seconds while you are in the pits to switch to the Sensors List, and check that both GPS and OBD are connected (green) and show reasonable update rates (which is a clear signal data is coming in). The most frequent issue is the wifi connection which can e.g be disturbed by some other wifi-s etc.
tobys1
Post by tobys1 »
Getting to grips with the Pro edition in conjunction with my 4s and go-pro.
Have the lap data and go pro fotage on my iphone, but the overlay function only lets you pick the file from the camera role, and i cant get the file into that folder?
You need to sync the file to the camera roll. Check you iTunes Photo(!) sync settings, and select videos to be included.
tobys1
Post by tobys1 »
Thanks Harry got it - lastly then how do I get it back onto the PC?
Synchronisation is two-way. So a overlaid video will be transferred back when you connect your iPhone the next time.
Dubbedown
Post by Dubbedown »
Hi Harry
I've successfully overlaid an external video (gopro) but for some reason the overlay function won't let me turn on obd ii data even though I know I had my GoPoint bt device was working at the time. Any ideas?
Dan
What do you see in the Lap's Details? Specifically Data Recording / Fixes?
Dubbedown
Post by Dubbedown »
Harry, screenshots below, let me know if I should click on a specific field:
