Android 13 issues? Upgrade to GP edition and external BT connections
Sideshow
Post by Sideshow »
Hi Harry
I have the new Samsung S23 Ultra with Android 13.
I have some issues:
- cannot upgrade on the grand prix edition -> remains in petrolhead edition
HLT GP upgrade issue.jpg (29.08 KiB) Viewed 8723 times
- cannot connect to any external bluetooth devices (GPS, OBD) [I tried the expert setting Force Insecure BT Connection]
HLT bluetooth issue.jpg (22.17 KiB) Viewed 8723 times
Doesn't it work for android 13 at all?
Cheers
Re: Android 13 issues? Upgrade to GP edition and external BT connections
I have not tested Android 13 yet. The reason for these messages are:
1) Add-ons: this means LapTimer can't access PlayStore with the ID configured currently. Please start PlayStore and make sure you are logged in.
2) Bluetooth: this means Android does not allow LapTimer to access Bluetooth. Please check permissions in Settings app.
Sideshow
Post by Sideshow »
Thanks for the quick answer!
Device is permanently connected (logged in) to the Play Store...
I tried also giving the HLT app all permissions. Doesn't work. There is no specific BT permission anyway.
Sideshow
Post by Sideshow »
Update: First issue with the Upgrade to GP version is solved. I opened explicitly the Play Store and then HLT got the connection
O.k. I will update one of my test devices to 13 and check if I can reproduce the problem. I'll come back.
P.S. Which BT sensor do you use?
Sideshow
Post by Sideshow »
Harry wrote: Wed Apr 05, 2023 9:59 am O.k. I will update one of my test devices to 13 and check if I can reproduce the problem. I'll come back.
Great, thank you very much!
My next trackday is mid of May, so its not super urgent. ;)
Sideshow
Post by Sideshow »
When I tap on "Add BT device" the app crashes:
HLT bluetooth issue v2.jpg (47.26 KiB) Viewed 8710 times
This is to add paired BT SPP devices. The crash will be related to the problem with permissions. Should not happen, but probably a code path never used before 13...
Please send information on the BT LE device you tried to connect.
Sideshow
Post by Sideshow »
Yes I paired my two BT devices first and then I wanted to add them. Did work without any problem on my old Smartphone.
I use these two devices:
OBD -> OBDLink MX BT
GPS Logger -> Qstarz BT-Q1000eX (10Hz)
