OBDII Data
Re: OBDII Data
LapTimer ‣ Analysis ‣ Realtime ‣ Engine is exclusive to LapTimer Grandprix and not included in Petrolhead. Two options:
#1 upgrade to GrandPrix from LapTimer ‣ Administration ‣ Add-ons ‣ GrandPrix Upgrade
#2 use the limited set of engine data shown in LapTimer ‣ Analysis ‣ Realtime ‣ GPS
On #2: once you connect an OBD adapter in an app edition not supporting Engine View, the GPS View will change and show a limited set of value in the bottom row. Tap the right most gadget to flip through channels available.
west1785
Re: OBDII Data
Post by west1785 »
Great, thanks! Will update to GrandPrix edition, just wanted to make sure it's the correct one.
west1785
Re: OBDII Data
Post by west1785 »
Any idea why I can't see oil temperature? I can see all the other live data, except oil temp. I'm using TONWON BTLE with GP Edition with a Porsche Cayman 987.2.
PitrsRS
Re: OBDII Data
Post by PitrsRS »
west1785 wrote: Sat Apr 24, 2021 6:11 pm Any idea why I can't see oil temperature? I can see all the other live data, except oil temp. I'm using TONWON BTLE with GP Edition with a Porsche Cayman 987.2.
Hi, that´s quite normal on "VW" cars. Not every car can provide oil temp via OBD dongle, even if you can see temp via VCDS software or on dashboard etc.
I tried it several times on different cars. Without success (Toyota Yaris 2016, Skoda Octavia RS 2010, Skoda Fabia 2018 and Leon Cupra 2016)
2016 SEAT Leon CUPRA 290 ST
PitrsRS
Re: OBDII Data
Post by PitrsRS »
Or you can try to set Custom PID in the app, then, maybe it will work.
Here is the list of PIDs
https://en.wikipedia.org/wiki/OBD-II_PIDs
west1785
Re: OBDII Data
Post by west1785 »
Thanks, I'll give it a try.
