How to find tire temperature?
solbergen
Post by solbergen »
Hi, running Petrolhead with V23.0.13 - with rejsarubber tire temp monitor connected and visible - showing 8hz.
However, i am unable to see the tire temp GUI so that i can get the sensor properly aligned with my tyres, and verify that things are working. Would like to do this prior to going to the trackday - so as to not spend time on that there...
Is it possible to get the GUI up without going to track?
solbergen
Re: How to find tire temperature?
Post by solbergen »
Tires tab showed up after restart of phone / HLT. However now I get Java errors trying to open tires page. :(
See attachment
Thanks, I will check and add a fix. The fix will get available as part of the *next v24 beta* update in case you want to get your hands on it fast. I think it will be in 2 or 3 days. See viewtopic.php?f=11&t=5737 for the details.
Am I right that this occurs when displaying the Tires View with a motorbike as current vehicle?
solbergen
Post by solbergen »
Yes, you are right. This is with only one sensor connected as well, a rear wheel sensor.
solbergen wrote: Sat Jul 18, 2020 1:11 pm Yes, you are right. This is with only one sensor connected as well, a rear wheel sensor.
One sensor is no problem, but the motorbike layout failed for the last v23 release. The v24 beta versions of LapTimer has this fixed already.
solbergen
Post by solbergen »
I have updated to the V24 beta (Last updated july 9th) but i am still getting this bug.
As soon as i try to enter the tires page (without the sensor connected atm, as it is on my bike, and i am away for vacation), the app crashes and i get a notification regarding integer to float conversion fault. I have reported the issue through the android reporting system.
Ok, I will check.
Rechecked. The fix is working, but I need to release a new beta version first. :-) The current beta is not yet on the latest state.
