I'm running an iPhone 6S on iOS 10.0.2 with Grand Prix Edition V20.1.4.
I captured a bunch of laps around my circular driveway (kid's power wheels vehicle), and got the flipped video issue. I flipped the video the correct way with an iPhone app, then re-linked it in the Lap Timer app. It looks good in preview mode with the overlay correctly showing. I click Export, and it takes a few minutes to crank through the export operation (about a 12 minute clip). When its done exporting, it shows the video without the overlay in the photos app. When I click play in the lap timer app, it also shows no overlay. I click "revert", then play, and it again (in the lap timer app) shows the video correctly with the overlay.
I've tried exporting several times, but each time I get the same issue. How can I rectify this? I can also apply the overlay through Final Cut Pro X if there's a way to just export the overlay section, but I can't find that function. The overlay configuration has everything turned on except for reference video. I don't have standard or extended options since I'm using only the phone (no accessories).
What are your thoughts on things to try next?
Overlay not present in exported video (iOS 10)
Re: Overlay not present in exported video (iOS 10)
Please post a snapshot of the lap's details Video section and the Overlay Configuration screen.
The screen shots are below. Also, I updated to v20.2 and git didn't remedy the overlay issue.
- IMG_0353.PNG (165.99 KiB) Viewed 1559 times
- IMG_0352.PNG (121.3 KiB) Viewed 1559 times
second set of screen shots
I think the lap details snapshots are missing? It is probably better you export the 12 minute lap to .hlptrl and send it to me (Harry@gps-laptimer.de). The problem with the missing overlay is probably due to the lap length or structure. I will check if I can reproduce the issue.
Sorry, they should show up in this post. I'll email that file to you.
Rob
Rob
- IMG_0351.jpg (139.58 KiB) Viewed 1538 times
- IMG_0350.jpg (148 KiB) Viewed 1538 times
