Overlay not present in exported video (iOS 10)
rob968
Post by rob968 »
I'm running an iPhone 6S on iOS 10.0.2 with Grand Prix Edition V20.1.4.
I captured a bunch of laps around my circular driveway (kid's power wheels vehicle), and got the flipped video issue. I flipped the video the correct way with an iPhone app, then re-linked it in the Lap Timer app. It looks good in preview mode with the overlay correctly showing. I click Export, and it takes a few minutes to crank through the export operation (about a 12 minute clip). When its done exporting, it shows the video without the overlay in the photos app. When I click play in the lap timer app, it also shows no overlay. I click "revert", then play, and it again (in the lap timer app) shows the video correctly with the overlay.
I've tried exporting several times, but each time I get the same issue. How can I rectify this? I can also apply the overlay through Final Cut Pro X if there's a way to just export the overlay section, but I can't find that function. The overlay configuration has everything turned on except for reference video. I don't have standard or extended options since I'm using only the phone (no accessories).
What are your thoughts on things to try next?
Re: Overlay not present in exported video (iOS 10)
Please post a snapshot of the lap's details Video section and the Overlay Configuration screen.
rob968
Post by rob968 »
The screen shots are below. Also, I updated to v20.2 and git didn't remedy the overlay issue.
rob968
Post by rob968 »
second set of screen shots
I think the lap details snapshots are missing? It is probably better you export the 12 minute lap to .hlptrl and send it to me (Harry@gps-laptimer.de). The problem with the missing overlay is probably due to the lap length or structure. I will check if I can reproduce the issue.
rob968
Post by rob968 »
Sorry, they should show up in this post. I'll email that file to you.
Rob
