Apple Watch
Henry_Au
Apple Watch
Post by Henry_Au »
Just noticed the apple watch in the accessory section. Can you please explain how I can use it wit laptimer? any improvement in watch ios 2?
Cheers,
Henry
Re: Apple Watch
It shows the current and last lap time - pretty much a simplified Timer view. It is possible to cancel and reset timing in addition. The solution is pretty limited by WatchOS 1 capabilities and is planned to be improved sometimes in the future. The planned version will display the lap history and enable work out mode for the faster sampling rate. Real time features will be removed again because they add little value. Today, you need to enable work out mode manually to get reasonable heart rate recordings.
Bartrs2
Re: Apple Watch
Post by Bartrs2 »
hello I can not get the heart rate watch with my apple in order to integrate the video
Re: Apple Watch
Please check:
1) Do you run LapTimer GrandPrix?
2) It is recommended to switch the Apple Watch to Workout mode while driving. Otherwise, the update rate of measurements is so low it hardly generates any reasonable data per lap. You can check the rate recorded in the Health Kit app. In case you do not get the heart rate gauge or the Heart Rate Chart (Data Recordings), please verify there is really data available in HK for the time range of the LapTimer recording. NB: LapTimer does not store any HK data locally, it requests data from HK when displays / overlays are requested.
Bartrs2
Re: Apple Watch
Post by Bartrs2 »
Harry wrote:Please check:
good morning heart rate is recorded in The application iphone but in the analysis of time on the chart appears
Bartrs2
Re: Apple Watch
Post by Bartrs2 »
Monika
Re: Apple Watch
Post by Monika »
please check first check if within the health app -> Sources -> LapTimer is enabled for reading health data.
Second: Please double check if heart rate data exactly sits within the lap time.
If still not working, please send screenshots of each heart rate datapoint (detail view of each data point as we need the precise second) and the export (.hlptr) of the lap (only the relevant lap!) to tracks@gps-laptimer.de
- Monika
Harry's LapTimer Team
scmcint
Re: Apple Watch
Post by scmcint »
Harry wrote: Fri Apr 22, 2016 10:40 amLapTimer does not store any HK data locally, it requests data from HK when displays / overlays are requested.
Presuming the prerequisites are met (Laptimer enabled within Health app, workout recorded on Apple watch), the Heart Rate data should appear as available data during Overlay Configuration?
Just trying to understand as this feature is not documented within the Video Documentation PDF.
Thanks.
Re: Apple Watch
There is no configuration for Health overlays. In case you run GrandPrix (or upgraded Rookie / Petrolhead) and health data is available for the time range of a lap, heart beats are added automatically.
scmcint
Re: Apple Watch
Post by scmcint »
Ah interesting. I will give it a try this season. Thanks.
