Disable automatic track change?
tajmahal
Post by tajmahal »
I am trying to use lap timer with my bicylce on smaller roads around my house, where I have lots of overlapping track configurations. Lap Timer permanently seems to automatically switch back and forth between tracks. Is there a way to disable this automatic track switching and have it just react to the triggers that belong to the currently active track?
Tobias
Re: Disable automatic track change?
That is how LapTimer is designed. You (almost) never select a track but leave this decision to LapTimer. This allows it to load tracks you drive regularly and reduces the risk of a wrong setting (leading to missed laps). While this is optimal for maybe 90% of the users, it is not for users driving one track in different configurations. These users simply load the configuration they drive next using Load Track. LapTimer will detect a conflict and recommend to purge conflicting Track Sets.
What remains are users with conflicting track sets not stored in our database :-)
So for you it is best to backup your track sets using LapTimer ‣ Lap List ‣ any track section ‣ first row showing "User Defined Track Set" ‣ Certify. Send the export generated to yourself (instead of Tracks@gps-laptimer.de) and keep this exports in your mailbox. Now, if you want to change to a specific configuration, open the corresponding mail, and import the attachment (tap it and select LapTimer). When asked, confirm you want to purge conflicting track sets.
NB: conflicting track sets are bad, they can confuse LapTimer and make recording fail completely.
tajmahal
Post by tajmahal »
Thanks for the quick reply!
What you describe sounds like a rather cumbersome workaround though. I guess I'll just limit taking time to a single track configuration then.
Any chance you'll be adding a "disable automatic track switching" setting?
Tobias
I have an "in-activate track" request on my list - which is probably a better solution than allowing a complete switch of concept by a setting. It isn't scheduled yet.
tajmahal
Post by tajmahal »
Alright, I'll stay tuned then.
Tobias
