App crash when changing orientation
fredsiva
Post by fredsiva »
I just upgraded to 16.6.2: and systematically crashes when rotating the iPhone4 a few times, here is the scenario:
1- start app in portrait mode
2- go to G-Meter
3- rotate to landscape
4- Strangely enough, HLP now shows me the map view...
5- rotate back to portrait mode
6- change from Map view to G-meter view
7- rotate again to landscape mode
8- I can then see the G-Meter in landscape for 2 seconds, and then app crashes
Note that step 6 could be changed to : "rotate a few times while in Map view", will aslo crash the HLP.
Did I do anything wrong with this great App? Thanks for your help.
Re: App crash when changing orientation
I have not been able to reproduce that, probably is depends on the position the Acceleration view is placed in the tab bar or something timing specific... You may send be your crash logs to further track this down: http://www.trilinkee.com/crash_logs.html
On #4: as there is no Acceleration view in landscape, LapTimer chooses a different view. So this is as expected.
