Current .vbo format to work with driftbox .vbo format
Canyonfive
Post by Canyonfive »
Current .vbo format to work with driftbox tools .vbo format
I was surprised one doesn't work with the other. It would be especially helpful as I can separate each lap and adjust for sensor drift.
Re: Current .vbo format to work with driftbox .vbo format
LT's .vbo export should certainly work with vbo tools as it has been created for it. Problem is the .vbo format is not well documented. Specifically, you probably need to adjust the triggers exported by LapTimer. vbo tools seem to use a different approach to detect triggers and this seems to generate problems from time to time. My test cases for some German tracks finally worked well, but as state above you will probably need to adjust the trigger definitions within the vbo file for other tracks. The current export is the 'best can do' for LapTimer...
