Charlotte Motor Speedway (Prior Lowes Motor Speedway)
nc94vette
Post by nc94vette »
Does anyone have plans to map out Charlotte Motor Speedway? They have a road course that uses most of the "big track" and also goes into the infield to make a road course that is about 2 miles long. HPDEs are run there with car clubs like NASA.
nc94vette
Re: Charlotte Motor Speedway (Prior Lowes Motor Speedway)
Post by nc94vette »
If this track isn't mapped out before I go (2/3 July), how do I map it out myself? Help please!
Please check the tutorial on http://www.gps-laptimer.de/Tracks.html
You may read some background information on triggers first: http://www.gps-laptimer.de/Trigger_Logik.html
But - it is still a lot of time till 2nd of July ;)
nc94vette
Post by nc94vette »
Thanks Harry! You are the best! I just sent the track into you for certification. Hopefully I did everything right ... since this is my first try. I was deliberate about it and I think it is what you need. Just let me know if I messed up. :oops:
Thanks again! :D
Tom.
Thanks Tom, perfect, it is online now.
ckowalc
Post by ckowalc »
There are several configurations of this track that are missing from HLT:
This one (can be configurated w/ and w/o either/both T11 and T15 chicanes on the oval)
This one (can be configurated w/ and w/o either/both T12 and T16 chicanes on the oval)
Even like this (both I think it is rare to run this configuration?):
Here is a satelite view for reference:
Many tracks show the huge number of configurations that can be ran for advertising reasons. Many are not used in practice. In case you go for a track day and know a specific - and missing - configuration will be driven, send a mail to Tracks@gps-laptimer.de a few days ahead. We will add it. In case this doesn't work, simply load a configuration using the same start / finish position as your configuration. This will work and can be sorted out later.
ckowalc
Post by ckowalc »
Ok I emailed the 2 configurations I have run.
CMS_Short Infield.png (552.48 KiB) Viewed 30064 times
CMS_Long Infield.png (361.7 KiB) Viewed 30064 times
Monika
Post by Monika »
thanks for pointing towards the used configurations of CMS.
Now, two new configurations are available for download:
In the app: Admin->Add-ons, update the list with button top right.
Afterwards search for CMS.
A list of 3 CMS configuration, two new ones:
- CMS NAS Roval (the new version since 2015)
- CMS Alternative Road
The old CMS with id 1245 has been moved to section outdated.
- Monika
