Jittery video?
Sssoon
Jittery video?
Post by Sssoon »
Hi. I have had great success using Laptimer with wonderful video quality in the past on my iPhone 4S. But, starting perhaps a month ago, my videos are jittery. It is almost as if the image stabilization is turned off. Here is an example:
http://www.youtube.com/watch?v=hY9N4fdQnls&feature=plcp
I have checked my mounting and everything else physical ten times. It is all the same as back in the summer when I seemed to get these effortlessly smooth videos. Has anyone else hit this problem? Solutions?
Pete
Re: Jittery video?
iOS6 turns off the image stabilizer by default. There has been a lot of critics on the stabilizer as it INTRODUCED additional jitter when used in cars... For your situation, it seem it making the situation worse. I will check how to allow the user to turn it on / off and add a setting to the next version. Till then, please try stabilizing your mount by e.g. letting the mount sit directly in your dashboard.
Canyonfive
Re: Jittery video?
Post by Canyonfive »
I have great results rubber banding mine to my rear view mirror while inside its otter box case. results are http://www.youtube.com/watch?feature=pl ... JkKGngvrhE
