Using HT with my Hydra EMS. Can I add its Log data afterward
Canyonfive
Post by Canyonfive »
Using HT with my Hydra EMS v2.5. Can I add its Log data afterward its available as a csv output.
I read in this topic http://www.gps-laptimer-forum.de/viewto ... hilit=vbox that I can export it to vbox. If I log in 10hz (or 5hz or anywhere in between) can i add to your logs via a csv editor like csved. Send them back to your app then export to the vbox file?
Re: Using HT with my Hydra EMS. Can I add its Log data after
The only import interface is the .hlptrl file format. Everything else is export only. So currently, there is no way to import csv files. I have the feature request to import logger data on my list, depending on the demand it will make it to a release sometime :-)
Canyonfive
Thank you. Also apparently it can connect to aim-sportline products. http://www.aim-sportline.com/download/e ... 01_eng.pdf
Is there an addon where an iphone can accept this kind of input? its a serial output RS232rx?
They are not compatible / connectable to the Apple world, that's a different space.
