No GPS Plots
shockerindustries
No GPS Plots
Post by shockerindustries »
Hi Harry
I've recently done a track day at Oulton Park. I download the track and it shows all the POI's on the map but in video mode the gps map plot is not displayed.
I've downloaded a few more tracks and checked to see if they have plots.....but there the same. No plots available.
Although....the Nords BTG shows the map no problem??
can you help as i have a track day at anglesey next week :?
Re: No GPS Plots
The track sets have POIs only. The actual plot is derived from your driving. You will get displays (video view and elsewhere) once you have recorded a lap successfully. For Oulton Park - do you have laps including data recording? Please check the Lap List, select one lap, and check if you see the shape in section "Data Recording" (namely "Preview").
shockerindustries
Re: No GPS Plots
Ohh I see now. For some reason it didn't work properly on oulton... I am a newbie though.
Did nürburg this summer and it worked amazingly.
Unfortunately though I deleted the app and reinstalled thinking there was a problem with it so lost my lap lists.
Thanks for clearing things up Harry
Re: No GPS Plots
Sorry to hear - next time run a full export using .hlptrl format - you can use it to restore later.
shockerindustries
Re: No GPS Plots
Thanks Harry and thanks for the quick response
