I am wondering if there is a way to duplicate an existing track to modify it ?
To precise : when I am at Yas Marina, we are using different track configurations :
- 1 where we have to take the chicane in the big straight
- 1 where we bypass the North part and cut thru the Cork Screw section
Can I duplicate and edit the Certified Yas Track, or do I have to re-create it from scratch ?
Thanks for your advise.
Arnaud
Duplicate existing Track for further Editing ?
Re: Duplicate existing Track for further Editing ?
You can use the existing track set and add / delete triggers and pois. You can then rename the track set and also submit it for certification.
