External GPS Detection
tulloch
Post by tulloch »
I'm finding that if I introduce the Dual GPS while HLT is running it is not detected. (iphone 5, latest HLT). I need to re-start HLT before the external unit is recognised. Is this expected behaviour?
Re: External GPS Detection
LapTimer usually receives a notification from iOS when an external accessory is connected. In a next step, it tries to connect to it. I will check if I can reproduce this behavior. As LapTimer disconnects and reconnects every time it is back- and foregrounded again, you may try a simple Home + LapTimer restart.
tulloch
Post by tulloch »
Well I can't reproduce it now, every way I try it works fine. Sorry about that.
Please just come back once you get it again. The crash will be fixed, I hope the duplication will go away too.
