How do I get to advanced settings in v16?
Gernby
Post by Gernby »
I upgraded to V16 recently, and decided to reset all settings back to default, since I've had endless troubles with every version I've ever tried.
Since I have an event tomorrow, I decided to be proactive, and try to figure out if I can get this version to work BEFORE the event. So far, it does seem to work, but I can't access many of the "MORE" screens. When I click on "More", I can only see the following:
Addons
Help
Timer
Online
Vehicle List
Guide
Classic
I can also see these items in the toolbar at the bottom:
GPS
Accelleration
Map
Lap List
I am not sure what else I should see, but it seems that I should also be able to access the following:
Settings
Sensors
When I click the "Edit" button on the "More" screen, I only see options to select the 10 screens I already have access to. Please help!
Re: How do I get to advanced settings in v16?
[Moved to Using LapTimer]
Most probably you have activated Easy Mode / turned off Advanced mode. Please navigate to Guide, press Define User, and enable Advanced Mode again. This will make the missing views appear again.
