European track: Mantorp Park. Unable to download, plz help!
andreas.e
Post by andreas.e »
Hey guys!
Im driving on the track Mantorp Park this weekend. And Im trying to download it into my Laptimer Pro app but it does not work!
It says Error 64. What does that mean!?
I bought the app + windshield mount just for this event and I would be sad to see it was a waste of money :(
Re: European track: Mantorp Park. Unable to download, plz he
Please try again now. In case it does not work and generates the same error, please refresh the Track list (button in the top left), and try again. The old set had a data problem that is fixed now. However, the version with the named problems is probably cached. The Refresh should help getting a fresh version.
andreas.e
Post by andreas.e »
Nice! It works!
Thank you so so so much! :)
dpollard
Post by dpollard »
I'm having the same issue with Europe : Blyton Park too (1293 ?) , same Error 64 on both Laptimer Pro (iPhone) and on Laptimer Trainer (iPad).
Tried refreshing the database (rather than updating), but still getting the same error.
Hi again,
Binetto-TrackSet.hpoil
Castelloli-TrackSet.hpoil
KotaBatuRun-TrackSet.hpoil
Montlhery-TrackSet.hpoil
MantorpPark-TrackSet.hpoil
BlytonPark-TrackSet.hpoil
all suffered from the same issue. I have updated them on the server a minute ago. In case they are loaded in their old version, you need to try again later as they are cashed somewhere on your phone (by iOS).
dpollard
Post by dpollard »
You really are a star ! Can't recommend you enough.
Thank you for sorting out.
dpollard
Post by dpollard »
I might have spoken too soon about sorting out - I'm still getting the Error #64 when trying to get Blyton Park.
Have tried reloading the entire list, and using various network providers in case it was cached. Am I in the scenario of having to rebuild my LapTimer settings ( which I presume will lose my previous laps at other circuits )
It is (most probably) not cached within the app, but somewhere in iOS. These cached files typically expire at some point in time - after which loading the track set will go back to the server to find the updated version. Don't ask why the change is not detected directly, I have changed to policy to check the server directly for the next version already. In case you can wait some days, just try again later. Otherwise, I'd need to change the file names to force a new load. Updating the list is not needed / helpful as longs as file names are not changed.
Sorry for the pretty technical reply, short version: it will resolve over time automatically. :-)
So, I have renamed the tracks above so caching will be worked around. This time, you need to refresh the Tracks list first ;-)
