how to see G forces in detail? other simple Qs
ChuckMcCoy
Post by ChuckMcCoy »
Greetings from Dallas. New to Harry's and new to iPhone....got the iPhone to run Harry!.
Got the recommended GPS upgrade, good mounting & I got an 18' cable & hang the GPS unit in the open air just 1/2" below the window sill in my 2000 Z3 roadster. Seems to work great. Have used it at 2 track days, TWS and HRC. Maybe will use video again, but didn't while at HRC.
But...
During 1st weekend (TWS) I used it the track map with the green/yellow/read for each lap would expand into finer detail by touching the arrow at the right. Then I got to using the "more 3 dots" to see details. At my 2nd day it did great recording data, but when I try and expand the 1st level map it turns blue for a moment, then won't proceed to more details.
Help. Know the answer is obvious, I just don't know it.
Re: how to see G forces in detail? other simple Qs
Do you have the latest LT version installed? You may export this specific lap to .hlptrl and send it to me (Harry@gps-laptimer.de). Maybe there is something about the data that makes LT not open the data recording area.
