LapTimer (Standard, Pro, Trainer) v16.0.3 submitted
Sitting in an Internet Cafe in Göteborg, Sweden, I just submitted the next bugfix release to Apple. As usual, it will go through a review and approval process so you can expect in approximately 5 working days on AppStore. This release has the following change list:
  • Some smaller bug fixes (status bar handling, Vehicle and Video List title)
  • Improved lap list scrolling - automatically selects last lap now
  • Improved data base check (faster, added vehicles, removed hanging "Check Data")
  • Fixed issue with screwed up views after rotation in Video View
  • Improved fix alignment for GPS, OBD, acceleration
  • Fixed issue with high acceleration update rates (dropped OBD fixes)
  • Added confirmation to Delete lap function
  • Changed Expert Setting from "Block Below" to "Block Above"
  • Added the Expert Setting to allow triggering at low speeds again
Re: LapTimer (Standard, Pro, Trainer) v16.0.3 submitted
Wow, that was fast. The Pro and the Standard versions are approved already. They should become available in a few minutes...
**betsy**
Post by **betsy** »
Strange thing is in the app store it's still showing 16.02 and won't let me update?
**betsy**
Post by **betsy** »
I'll check with Apple why 16.0.2 Standard is still not showing up. It has been approved jointly with the Pro version.
**betsy**
Post by **betsy** »
Should it not be showing 16.0.3 in the updates section of the app store?
Real strange why it shows 16.0.2 as it seems to be stuck and shows it as installed, which I know it is the version I'm already running but yet it remains showing its wanting to update...
**betsy**
Post by **betsy** »
Any news on why the app store is still trying to make me update to v16.0.2 when In already running this version!?
This has been a problem in AppStore processing. Apple fixed that, so 16.0.3 is available for LapTimer Standard now.
P.S. Trainer 16.0.3 is online too.
