[SOLVED] V16 crashing when adding POI
Posted: Fri Aug 17, 2012 10:24 pm
by lisocayman
The app keeps crashing when I add a poi to a downloaded track. Specifically Thunderhill. After adding the poi on the map going back to the lap list crashes the app
Posted: Fri Aug 17, 2012 10:28 pm
by lisocayman
Actually testing it a little more the app crashes even if you don't add a poi.
Navigate to lap list, open the map of the track. The tap lap list and it crashes.
Re: V16 crashing when adding POI
Posted: Fri Aug 17, 2012 10:33 pm
I load Thunderhill, select this track in any of the timer views (not necessary, but thought you had selected it due to some timing), goto the Map View, add a POI, change the name, and select Thunderhill as the POI Set. Go back to Lap List - nothing happens.
Did you do anything different? Maybe you better send a crash log, please check http://aplus.rs/apple/how-to-find-crash ... sta-and-xp for a how-to.
Posted: Sat Aug 18, 2012 5:46 am
by lisocayman
Hi Harry. If I add one poi it works but when I come back from the lap list to the map to add another it crashes when I tap the lap list.
I deleted the app and did a fresh install with the same problem. I'll get the logs and send them. How would you like me to send them?
Posted: Sat Aug 18, 2012 7:45 am
Please follow the instruction above and send the file as attachment to my email address at Harry@gps-laptimer.de Please add a comment so I get the relation to this post.
Thanks, Harry
Posted: Tue Aug 21, 2012 6:34 pm
by lisocayman
Harry - I emailed you a number of crash logs yesterday. Please let me know what you find. At the moment it seems to be working okay. I did a full restore of my phone and re-installed the app.
Posted: Thu Aug 23, 2012 4:32 pm
by K20Performance
I have the same issue since the update, if i go in laplist and look at my laps or try to link a video LT crashes.
It seems to do this randomly when i m doing something and then go back to the menu it just crashes.
I never had this issue before goin to V16.
I also freed up space on my iphone.
I will mail you with the crash logs.
