[SOLVED] V16 crashing when adding POI
lisocayman
Post by lisocayman »
The app keeps crashing when I add a poi to a downloaded track. Specifically Thunderhill. After adding the poi on the map going back to the lap list crashes the app
lisocayman
Actually testing it a little more the app crashes even if you don't add a poi.
Navigate to lap list, open the map of the track. The tap lap list and it crashes.
Re: V16 crashing when adding POI
I load Thunderhill, select this track in any of the timer views (not necessary, but thought you had selected it due to some timing), goto the Map View, add a POI, change the name, and select Thunderhill as the POI Set. Go back to Lap List - nothing happens.
Did you do anything different? Maybe you better send a crash log, please check http://aplus.rs/apple/how-to-find-crash ... sta-and-xp for a how-to.
lisocayman
Hi Harry. If I add one poi it works but when I come back from the lap list to the map to add another it crashes when I tap the lap list.
I deleted the app and did a fresh install with the same problem. I'll get the logs and send them. How would you like me to send them?
Please follow the instruction above and send the file as attachment to my email address at Harry@gps-laptimer.de Please add a comment so I get the relation to this post.
Thanks, Harry
lisocayman
Harry - I emailed you a number of crash logs yesterday. Please let me know what you find. At the moment it seems to be working okay. I did a full restore of my phone and re-installed the app.
K20Performance
Post by K20Performance »
I have the same issue since the update, if i go in laplist and look at my laps or try to link a video LT crashes.
It seems to do this randomly when i m doing something and then go back to the menu it just crashes.
I never had this issue before goin to V16.
I also freed up space on my iphone.
I will mail you with the crash logs.
