Export all sessions
cagotzmann
Export all sessions
Post by cagotzmann »
How do you export all sessions for a track. When I do this is makes 1 file. I need separate files for each session.
I have a total of ~ 100+ sessions over 3 years. If I select the day then it makes again 1 file for the day. Select the session makes 1 file.
It would take hours and hours to select each session to create separate files.
Am I missing something.
Re: Export all sessions
LapTimer exports a lap, all laps of a track, a day, a session, or everything. Exports are always one file. In case you need an export for alle sessions of a track, you need to export all laps of this track and split the result afterwards. This will require some scripting to make it do-able.
