Page 1 of 2
goPoint GL1 OBD-II
Posted: Sun Apr 17, 2011 10:58 pm
by MasterC17
Any idea if we could get support for this product: http://www.amazon.com/goPoint-Technolog ... 00336S7KS/
It appears to work with DashCommand so I presume they would be willing to give Harry the API.
Re: goPoint GL1 OBD-II
Posted: Mon Apr 18, 2011 7:25 am
I was in contact with goPoint already, they provided me with everything I'd need to integrate. Two problems remain: I do not have a goPoint Dongle to test (but probably someone in this forum can help as remote tester), and I need to find the time to program this. In case you do not want to wait, please go for one of the ELM327 based WLAN sensors, they are supported already.
Posted: Mon Apr 18, 2011 8:23 am
by bulls23
I just took a quick look at the goPoint Homepage. Seems like this one too only supports never vehicles. Is there any supported OBD device out there which is capable of older protocols like KWP1281 ? Apparently this one does:
http://www.obdkey.com/wifi/index.asp
But they don't seem to be very interested in cooperating with Harry :(
Posted: Mon Apr 18, 2011 8:33 am
May anyone with an OBDKey WLAN at hand check if it works with LapTimer Pro 13.3?
Please goto Settings -> Expert Settings and set the OBD Host to 192.168.0.74 and Port 23.
Then please connect to the Dongle's Peer to Peer WLAN and start LapTimer Pro afterwards.
Navigate to Sensor List and check if a connection to 'Custom OBD' gets established.
Posted: Mon Apr 18, 2011 9:54 pm
by MasterC17
Harry wrote:Hi,
If I were to buy one could we work together to get the support for it? No rush.
Posted: Mon Apr 18, 2011 9:57 pm
OBDKey WLAN, yes, that should be possible easily. The goPoint takes more time as it uses a completely different communication scheme.
Posted: Tue Apr 19, 2011 2:13 pm
by MasterC17
Posted: Tue Apr 19, 2011 5:45 pm
MasterC17 wrote:I take it this would work: http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0548706544.
Looks like a (un)branded version of KiwiWifi?
Posted: Wed Apr 20, 2011 12:06 am
by MasterC17
Basically looks like a Chinese copy of the Kiwi so getting it to work should be easy. Hopefully it won't break in a year, may take the chance. Still trying to figure out the best combo for GPS & OBD-II.
Posted: Sat Oct 01, 2011 6:32 am
by doborder
Any news on goPoint GL1 OBD-II.?
With all the problems with wifi OBD-II connections, I would think this product with be high on your integration list.
My current setup is with OBD KEY and Bluetooth external gps via Roqy which works well except my OBD only updates at 3hz for my car... I wonder if the update rate would be better if I connect the OBD directly to the iPhone.
