goPoint GL1 OBD-II
MasterC17
goPoint GL1 OBD-II
Post by MasterC17 »
Any idea if we could get support for this product: http://www.amazon.com/goPoint-Technolog ... 00336S7KS/
It appears to work with DashCommand so I presume they would be willing to give Harry the API.
Re: goPoint GL1 OBD-II
I was in contact with goPoint already, they provided me with everything I'd need to integrate. Two problems remain: I do not have a goPoint Dongle to test (but probably someone in this forum can help as remote tester), and I need to find the time to program this. In case you do not want to wait, please go for one of the ELM327 based WLAN sensors, they are supported already.
I just took a quick look at the goPoint Homepage. Seems like this one too only supports never vehicles. Is there any supported OBD device out there which is capable of older protocols like KWP1281 ? Apparently this one does:
http://www.obdkey.com/wifi/index.asp
But they don't seem to be very interested in cooperating with Harry :(
May anyone with an OBDKey WLAN at hand check if it works with LapTimer Pro 13.3?
Please goto Settings -> Expert Settings and set the OBD Host to 192.168.0.74 and Port 23.
Then please connect to the Dongle's Peer to Peer WLAN and start LapTimer Pro afterwards.
Navigate to Sensor List and check if a connection to 'Custom OBD' gets established.
MasterC17
Post by MasterC17 »
Harry wrote:Hi,
If I were to buy one could we work together to get the support for it? No rush.
OBDKey WLAN, yes, that should be possible easily. The goPoint takes more time as it uses a completely different communication scheme.
MasterC17
Post by MasterC17 »
MasterC17 wrote:I take it this would work: http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0548706544.
Looks like a (un)branded version of KiwiWifi?
MasterC17
Post by MasterC17 »
Basically looks like a Chinese copy of the Kiwi so getting it to work should be easy. Hopefully it won't break in a year, may take the chance. Still trying to figure out the best combo for GPS & OBD-II.
doborder
Post by doborder »
Any news on goPoint GL1 OBD-II.?
With all the problems with wifi OBD-II connections, I would think this product with be high on your integration list.
My current setup is with OBD KEY and Bluetooth external gps via Roqy which works well except my OBD only updates at 3hz for my car... I wonder if the update rate would be better if I connect the OBD directly to the iPhone.
