So, i read that laptimer pro will auto calibrate.
But then i found the acceleration screen and it
Requires doing some straight line acceleration stuff?
What is the proper method to calibrate?
Do i need to use this screen any time i remount my phone?
How about when i change orientation? This screen
Seems to only work in portrait orientation.
Help with aceleration screen
Re: Help with aceleration screen
LapTimer v15 works in portrait in general, the Video View is the only exception. The acceleration view is primarily a specialized view for real time acceleration information. Automatic calibration works independent of the view selected, the assistant provided in Acceleration View is provided in case you want to see exactly what is going on / or in case you run into problems.
Thank for the quick response.
Doing my first trackday at PIR this week.
Looking forward to using laptimer.
