Wakefield Park now One Raceway
Engenia
Post by Engenia »
Hello Harry,
I understand you originally added "Wakefield Park" near Goulburn, NSW, Australia (TrackID: 1082), to your track list. This track was sold over a year ago, altered and re-named "One Raceway". It is now unique in that racing can be run in either directions, clockwise, known as the "Wakefield Circuit", and anti-clockwise, known as the "Shelley Circuit". The track has modified corners at each end of the main straight. At the southern end what was one hairpin is now 4 corners, 3 right & 1 left. I believe that the other end turn 2 is now two corners.
Would you be able to modify the configuration of Wakefield Park to that which is current and rename it "One Raceway - Wakefield" & add "One Raceway - Shelley"?
PS. Does HLT care if it reaches corners in the opposite direction?
If not, then the two configurations need not be separated.
regards
Errol
Re: Wakefield Park now One Raceway
Thanks Errol, we will check and add new configurations. When driving a track CW and CCW, two track sets are required. It is not about corners, which are used for displaying names in videos only, but triggers for s/f and splits. These are directional and will not trigger when passed in opposite direction. We'll let you know once the new tracks sets are online.
Engenia
Post by Engenia »
Thanks Harry.
regards
Errol
dodk168
Post by dodk168 »
Hi Harry Laptimer Admins,
Just wondering if the One Raceway track is ready on the app.
Looking forward to trying One raceway in the coming months.
Sorry, for rushing was more curious.
Regards,
Albert
Monika
Post by Monika »
Hi Albert,
Shelley configuration is already available at HLT with ID 2311 (if it is not visible searching Admin->Add-ons, please make sure to update the track list in Add-ons area with button top right).
Nevertheless it doesnt include the new corners, nor does the old Wakefield track.
The new track layout is yet not visible via satellite pictures to us,
so could you please send one recorded lap of each driving direction to tracks@gps-laptimer.de ?
We can use your recorded gps coordinates to set up the new turns and will publish the updated versions of both driving directions.
Many thanks,
Monika
Engenia
Post by Engenia »
Hello Monika,
I've emailed you a pdf of the new track layout. Google hasn't updated the satellite view yet, but the track is updated on https://latitude.to/lat/-34.84056/lng/149.68523 (From https://latitude.to If you search for the coordinates -34.84056 149.68523 it will pop up). Those coordinates are as near as I can tell those of the start/finish line.
It has also been updated on Mapcarta (https://mapcarta.com/W243863449)
regards
Errol
Monika
Post by Monika »
Hi Errol,
both configurations (Wakefield and Shelley) are now available in new 2025 versions.
In the App: Admin->Add-ons, update list with button top right.
Afterwards search for Wakefield or Shelley and they will be listed for download.
Regards,
Monika
Engenia
Post by Engenia »
Thankyou Monika, that's much appreciated. I plan to head out there in a couple of weeks
regards
Errol
