I am running an iPhone SE2 as my dedicated telemetry device, running Grand Prix v24.9. The only external devices I now use are OBDLink MX Wifi + Bad Elf GPS.
Problem 1 - OBD Device
Today however, the OBDLink MX seemed to stop working. It would not appear in the Sensory List under Available even though I know the device was connected and works. Within Sensory List, if I clicked on All, I then saw a generic OBD device appear... and after few seconds, it changed from generic to OBD MX Wifi, so I thought everything was fine. But upon coming home, I see that none of the engine data was recorded in any of my lap data.
For context, my SE2 wifi connections only 'knows' the OBD Link MX network and I have the setting so that it does not try to connect to any other network.
Problem 2 - GPS Fix
Secondly, must a cellular connection be maintained in order to utilize external GPS devices? My first session did not get a proper GPS fix so lap timer never started. I thought this was odd so I tested using GPS Buddy. And sure enough, I could not get a GPS fix when cellular was disabled. Only when it's on was it then working. I recall being able to use Lap Time with Airplane Mode On - has that changed in the last year or so?
I love the app but I've spent too much money on numerous combo of devices because right when I think I found the right set, something "changes" making those devices unreliable.
1. Kiwi 3 (BT LE) doesn't play nicely with RaceBox Mini (BT LE) -> Buy new OBD Link MX Wifi
2. Racebox Mini connection constantly interrupted by other devices nearby -> Buy older style Bad Elf
3. OBDLink MX Wifi doesn't work with GoPro 4 Wifi -> Just record / sync manually
4. OBDLink MX Wifi now isn't recognized by app at all...
Harry - I could REALLY use your help. I've been a loyal user for 10+ years but in all honesty, the app just becomes harder to use with each release. Back then my GoPoint BT1 + Emprum Ultimate + GoPro 3 worked seamlessly. But now my experience is the complete opposite.
