in expert settings, ( system section )
i guess refresh rate is GPS rate, so do i need to set 10 refresh rate if i have 10hz external gps ? ( already jailbreak, and btstack )
and what is repeat rate(2-8hz) ? i think default value is 4...
do i have to leave it ?
10hz setting, and repeat rate ?
Re: 10hz setting, and repeat rate ?
Both settings are not related to GPS. The first one is the display refresh rate which should not be changed. The second has no effect and will be removed in v16.
