Selected verify data, app crashed and now won't reopen
vafan13
Post by vafan13 »
24.8.1 on Android 12. Everything was fine then selected "verify data" and the app suddenly crashed and the phone said "laptimer closed because this app has a bug. Please update after the developer provides a fix for this issue." Since then if I try opening it it only shows the timer on a grey background for a second and then closes. Periodically it will put up the same "this app has a bug" message.
Not sure if it is relevant but a few minutes prior I had upgraded from petrolhead to grand prix.
Please advise, and thanks!
Re: Selected verify data, app crashed and now won't reopen
The upgrade is not related to the crash. This is most probably a database problem Verify Data revealed.
To get the app up and running again, the current (corrupted) database needs to be inactivated.
The procedure to do this is described here: viewtopic.php?t=6176
jihn23456
Post by jihn23456 »
The link over there ("To recover your data, follow instructions in [HOWTO] Restoring Automatic Backups") does not work.
Yes, the forum fails to display certain posts currently. I need to check.
