Turn off gear shift pop up
KAZUNA
Post by KAZUNA »
I think this red shifter popup is to suggest shifting up the gear (I can barely read it).
Is there a setting to turn it off?
I was under the impression that it was warning something but I would like to turn it off if it is just a suggestion.
Re: Turn off gear shift pop up
The shift flash is a warning once you approach the end of your engines rev range. It is a hint to shift up a gear to not run into the limiter. You can adjust its behavior: make sure you have set the correct Max RPM in your vehicle's details first. In case it is too low, you will see the warning too early. Furthermore, there is a percentage of this rev range the shift flash appears. For me, 85% works great. Mostly, I shift early enough to not get the flash, but it warns me in case I missed the threshold. Instead of turning the feature off by setting the percentage to 100%, I recommend increasing the current value slightly.
KAZUNA
Post by KAZUNA »
So I can simply set Max RPM higher enough (e.g. red zone end instead of red zone start) so I won't see the shift flash. Gotcha.
KAZUNA
Post by KAZUNA »
In my case, I can simply set Shift Flash to 100% as mine is DCT.
Please set the correct Max RPM, it is used in other areas too. To get no flash, use 100%
