Starting Sequence (Vbox Sport 20hz)
Ned Loh
Post by Ned Loh »
I have intermittent issues with the two not working with each other. Always at start up.
What order should I be turning on Harry’s in relation to the Vbox? I seem to recall reading something about the letting the Vbox get satellite lock (solid light) before turning Harry’s on, but I can’t find any reference to it now.
Using an older iPhone if that makes any difference.
Re: Starting Sequence (Vbox Sport 20hz)
Connection making with the VBOX is pretty complicated on a technical level. This may make it fail at times. I usually start LapTimer before powering on the VBOX. Please make sure to not run Racelogic's app in background. It will block LapTimer from accessing the VBOX.
