Adjusting sync
Rexton133
Adjusting sync
Post by Rexton133 »
I was using HLT on Friday at the circuit and was processing videos over the weekend
The set up was HLT as the data recorder and a GoPro Hero 8 synced up with HLT. The connection between HLT and the GoPro Hero 8 Black was fine.
My issue is that the synchronisation on the video is about 2-3 seconds off. No problem I thought I can just adjust by going back in as per the instructions here
viewtopic.php?t=4940
Unfortunately it does not seem to work and the video stays resolutely where it is. Any suggestions would be welcomed.
Re: Adjusting sync
When adjusting data / video sync, you need to change the sync point for the original video link (not one exported already). So in case you see a Revert button in Lap List / any lap of the session / Video section, press that to go back to the original video. Once this is done, adjust the sync point as described in the link above.
Rexton133
Re: Adjusting sync
Post by Rexton133 »
Many thanks. Will try that
