Checking RaceBox Mini
Rexton133
Post by Rexton133 »
I have HLT 24.6. Grand Prix edition. I have just purchased a RaceBox mini. How can I tell that the recording of the GPS signal is from the RaceBox Mini before I start a session.
Re: Checking RaceBox Mini
There are many options. You can bring up LapTimer ‣ Administration ‣ Sensor List. The Mini should be displayed as GNSS sensor with a 25 Hz rate. Otherwise, you will see your smartphone sensor in the list. When using the Mini, make sure you have LapTimer 24.5.2 (Android) or 24.5.3 (iOS) installed.
