I wish harrys was more like this...
Josh7owens
Post by Josh7owens »
http://www.s2ki.com/s2000/topic/952943- ... ry21708715
I lik the numbers on the gforces alot better then the way the current harrys app shows gforce. Also notice how much the dot moves. My iphone 4s harrys app is alot slower and doesn't even pick up small transitions.
Josh7owens
Re: I wish harrys was more like this...
Daniel
Post by Daniel »
It's $200 and does not work on the iPhone??? I'm glad HLT is nothing like that! :)
LapTimer v16 will have a configurable update rate for accelleration. Currently it is reduced to 10hz to save battery. Range possible is 10 to 100 Hz. At 30 Hz it is very agile already.
Josh7owens
$200 includes the price of the bluetooth GPS and OBD2 datalogger. :)
Yea I'd like the G meter rate as high as possible. Making it adjustable would be awesome! So are you saying on the next verson we can have it display number instead of the little graph. Kind of like the app I just linked you to?
The feature in SoloStorm I would most like to see in HLT is adding segments from the run map after the fact.
rscliofan
Post by rscliofan »
i prefer it the way it is on HLT, i have on board g meter but rarely use it, but then on track i use the computer for throttle mapping.
