When rendering out it would be great if you could pick which video to use for the audio track.
This is particularly useful when using GoPro in a skeleton case as the "main" camera, which is likely a common setup, as it has muffled audio even with the case modified, so being able to use the phone audio (pip video) would result in a much better audio.
Select audio track for rendering
cars4enjoying
- 20 or more Posts ★★★
