This required format conversion due to the size so I used libx265, hvc1 @ 1080p down from 4k in h264. I then transferred the file to my iPhone 11 selected in LapTimer by selecting add video, which is where the issues started.
First up when selecting the start point the scrub worked for a few seconds but then stopped updating the video still. Nothing would make it work again. Had to remove and retry, happens every time. In the end I found the right position using VLC and then selected the start using time as a reference.
Play seems to work but when I select export I get:
Code: Select all
Invalid master videoI'm running a new join with h264 to see if that helps so will report back, but wanted to see if this is a known issue?
