GLP Unexpected Timer Stop
Yellow
Post by Yellow »
Hi, we tried the Laptimer last Time.
The first set of 4 Laps worked perfect. (one Set Time and 3 confirmations)
But for the second part we had a slow set time.
The 3 Confirmation Laps we had to wait in the waiting area each for 3 minutes.
The Laptimer stopped every Time.
Is there a trigger that stopps the Timer if you stand too long?
Re: GLP Unexpected Timer Stop
Yes, there is a stand still "auto stop" after some time.
For tracks with a common start / finish, many users return from a cool down lap and forget to manually stop LapTimer.
Nils_99
Post by Nils_99 »
We had a similar Issue last weekend.
Is there a way to turn off this "auto stop" or increase it's timer? Whats the "stand still" time ?
If it's rainy and you are unsure abou yellow phases or even code 60, you tend to set a slow "set-lap" as described in the original post.
Greetings
-Nils
The timer is 3 minutes. A "stand still" is defined as a speed below 1.5 km/h. Both values are hard coded currently.
Nils_99
Post by Nils_99 »
Thankyou for the fast response! This will help us anyways!
-Nils
