RaceBox Mini
Mr. Knowitall
RaceBox Mini
Post by Mr. Knowitall »
I just received my RaceBox Mini and tried to use it with Lap Timer Rookie. It showed up on the sensor list, and I can see it when I go to the GPS page. But when I went to record a custom 'lap' on my way to work, it showed a bad GPS update rate and based on that and the path I have a hunch it was using my Android internal GPS. I noticed that the Grand Prix edition adds a feature to support GPS >20Hz. Is that my problem? Do I need the Grand Prix edition of Lap Timer to use the RaceBox Mini?
Re: RaceBox Mini
The >20 Hz policy is not valid any more. Actually it applies to VBOX Sport and ASL's RaceCapture devices only. So for the Mini, GP is not mandatory.
As the RaceBox Mini integration is pretty new - can you please recheck that the device is staying online for the whole drive? I'd suggest to use Analysis / Realtime / GPS View to check that.
Squirry
Re: RaceBox Mini
Post by Squirry »
Does the integration of Racebox Mini into HLT (I'm using the Grand Prix edition) include the accelerometer information?
Re: RaceBox Mini
No, makes no sense. Other than GPS, smartphone IMU units (gyro, acceleration) are high frequency and high accuracy sensors.
Squirry
Re: RaceBox Mini
Post by Squirry »
javoresku
Re: RaceBox Mini
Post by javoresku »
Not sure if this is the correct place, but I want to share my experience from a trackday yesterday.
I started HLT (Grand Prix, 24.6) on my Samsung Note20 and it automatically connected to a Racebox Mini. For the record - I Don't own a Racebox Mini.
I couldn't make HLT connect to either my Garmin GLO or the internal GPS on the phone until I found a place in the pits where HLT didn't autoconnect with the RaceBox Mini.
I have also reported the issue to the Racebox developers.
Re: RaceBox Mini
This is the typical issue with the mostly "open" architecture of BT Low Energy devices. They do not require pairing or credentials. So when LapTimer starts to discover sensors, it may find one in your neighbor's car and connect to it. Please note this only happens if your neighbor isn't connected currently, and LapTimer has no external connection to the sensor type (here: GPS) already. Moreover, once you are on track, the connection will break and be replaced by your own sensor.
javoresku
Re: RaceBox Mini
Post by javoresku »
That makes sense.
Just to confirm - when there are multiple GPS sensors available HLT defaults to the one with the highest refresh rate, am I right?
Re: RaceBox Mini
LapTimer prioritizes any external sensor over the internal sensors. It does not do a prioritization by rate or between external sensors.
Mr. Knowitall
Re: RaceBox Mini
Harry wrote: Thu May 26, 2022 4:27 pm The >20 Hz policy is not valid any more. Actually it applies to VBOX Sport and ASL's RaceCapture devices only. So for the Mini, GP is not mandatory.
Thanks Harry, I did a 'lap' today on a different custom 'track'. I was in the Analysis / Realtime / GPS View the whole time and it was showing data from the RaceBox Mini without any disconnects (that I could see). But when I later went to the analysis of the 'lap', it showed the data had been recorded at 1-Hz from the internal GNSS sensor. Is there some configuration I need to set that I may have overlooked?
