My BMW Z4 only updates the OBD at something like a nominal 1.3 Hz. It would be desirable to be able to select the speed source as GPS, as that has a higher update rate (and is also not quite as optimistic as BMW is with speedometer calibrations).
Perhaps something in the vehicle setup for the speed source selection, either OBD or GPS, or a selection for use sensor with available highest rate?
Mike
Option to select GPS as speed source when OBD connected
- karacticus
- 20 or more Posts ★★★
