Unable to export OBD data
CraftyBrewer
Post by CraftyBrewer »
I have new Veepeak OBDcheck BLE+ device plugged in to my Porsche 987. If I run a OBD App (Car Scanner), the device works fine. When I run HLT (Petrolhead) it "recognizes" the device in the sensor list, and seems happy, etc.
However, when exporting the post-session lap list .csv by email, I only get the GPS related data. The OBD related fields are empty.
Clearly, I've missed a setup task somewhere. Not been able to find anything in the instructions or FAQ's, other than I don't need to pair the device or run a OBD App.
Help most appreciated.
Alan
Re: Unable to export OBD data
Please make sure you kill any other OBD app when running LapTimer. They may block access from background.
The other most frequent issue is about protocol negotiation. LapTimer leaves this task to the adapter by default. In case it doesn't work (OBD update rate not shown / 0Hz), please select the proper bus protocol in Settings / Expert Settings / OBD Tweaks / Default Protocol. Refresh Sensor List to make sure changes are applied.
CraftyBrewer
Great. Thanks. Will try this.
